ODK Validate Errors: org.javarosa.core.log.WrappedException: Error evaluating /attempt2: java.lang.ClassCastException: java.lang.Double cannot be cast to java.lang.String => java.lang.ClassCastException[java.lang.Double cannot be cast to java.lang.String] >> Something broke the parser. See above for a hint. Result: Invalid
Not quite sure how to address this error message as "attempt2" is the saved file name of the xls and is not included anywhere in the form itself...
Thank you in advance,
Josh
can't really help, because I have no form to work off of.
One of your fields in the top level of the form must be using a number
where a string value is expected without first converting the number to a
string using the string(${fieldname}) function.
Result: Invalid
itself...
Josh
And, sorry, we've been trying to improve the degree to which the error
message references the offending field -- but there are still cases where
it does a bad job (and this seems to be one of them).
Chris
Result: Invalid
itself...
Josh
