Dear Amit,
Excellent. You are also doing lot in R programming and environmental research studies. Great to be associated with you through ODK. I just started learning and using R for my research work data analysis, may get some help from you to solve some of my issues.
Regards,
Senthil
Sure! I'd be happy to help. are you using base R or the tidyverse?
Hi Amit,
Thanks for a quick reply. I am using RStudio version 1.1.4. We can connect through email with more details.
Please send your reply to my email id senmalkisasb@gmail.com.
Regards,
Senthil
not what IDE are you using... whether your philosophy is base or Tidyverse. I'm talking about htis... I assume you're base... so prepare for your life to change!!!
Look into the tidyverse... your life will change. The entire process becomes more intuitive. Good luck!
Amit, I am using ggplot2 which is a part of tidyverse, excellent graphs. Could you please share your email.
Regards,
Senthil
