Hi:
Anyone know if it's possible to add a hidden prepopulated field to a form
which will be filled and submitted using Collect? AFAICS there doesn't
seem to be a Build option for hidden fields..?
If it's possible, can anyone post a sample or description of how to embed
the hidden field name and value into the form xml?
Nik
A hidden prompt is any prompt that exists in the bind or instance, but
doesn't have a corresponding body tag.
In this example, description is hidden. You can still refer to the
description in the form logic, but it will never show up as a prompt
in the UI.
Hidden field
Capture the image.
Capture the location.
On Tue, Jul 24, 2012 at 6:56 AM, blitheringeejit wrote:
> Hi:
> which will be filled and submitted using Collect? AFAICS there doesn't seem
> Thanks
> Nik
Can you please make it more clear on how to create the filed maybe by showing an example?? I still don't get the way you explain... Thanks Yanokwa
