Hello,
I would like to create a form that is quite similar to the household survey
in ODK.
In particular, I am interested in the barcode field.
I am using PurcForms to create forms, then rendering them to suit ODK.
Please advise on how I can create a barcode field for ODK [which inturn
calls the barcode app; similar to the way the GPS, or camera are called for
Coordinates and video/photo respectively]
Thanks.
Regards,
Eisah Kakyama, Mayanja
Grameen Foundation Uganda
+256 772 712 899
www.applab.org
www.grameenfoundation.org
"Transforming lives through innovations in Information Access"
hi eisah,
the easiest way to do this is to continue designing your forms in
purcforms. when you need to make a barcode question, make it a text
question for now. when you are ready to finalize the form and put it
into odk, you'll need to edit the form in text editor (like notepad++)
and change that question bind type to barcode.
i understand this is a little vague and technical but take a look at
http://code.google.com/p/opendatakit/source/browse/Household+Survey.xml?repo=forms#126
to see an example of a barcode question. if you run into problems, ask
on http://groups.google.com/group/opendatakit-implementers.
as a more permanent solution, i'll ask daniel to update purcforms with
an option for barcodes.
yaw
On Fri, May 7, 2010 at 01:43, Eisah Kakyama, Mayanja wrote:
> Hello,
> in ODK.
> Thanks.
> Regards,
> +256 772 712 899
> www.applab.org
Hello Yaw,
Will get back to you after trying this. Thanks.
Regards,
Eisah
On May 10, 3:00 am, Yaw Anokwa wrote:
> hi eisah,
> i understand this is a little vague and technical but take a look athttp://code.google.com/p/opendatakit/source/browse/Household+Survey.x...
> onhttp://groups.google.com/group/opendatakit-implementers.
> yaw
> > Hello,
> > in ODK.
> > Thanks.
> > Regards,
> > +256 772 712 899
> >www.applab.org
> Options:http://groups.google.com/group/opendatakit?hl=en- Hide quoted text -
> - Show quoted text -
