is it soil testing sensor will work on odk
Could you perhaps provide a little more information, eg filling out the template:
Also, wrt the soil testing sensor, are you specifically referring to Mapping Soil Conditions in Africa with ODK, or something else?
Thanks for your reply
We are using ODK As a reporting tool whereas we are capturing the Structural Data Like Water tanks,Rainwater harvesting tank which is developed in the Project Area. using ODK Geo Tagging photographs its works fine.
now we want to use odk as a sensor based application whereas it sensor can check the minerals of soils in farmers field.
can we do it ?
This is very interesting, there are sensors that connect via Bluetooth to smartphones. For example, Ph sensors for soil, soil moisture, soil temperature. Is there a way to collect this data?
if the sensor is connect to smartphone then we can easily get the data from the sensor reader and linked with ODK and take the reading and send it to the aggregate server.
Is there an example form for this?
first we have to check the sensor reading then only we can map it with sensor.
