How can I enable httpclient logging in ODK?
We have a strange issue where the upload of data is failing when on data plan but works fine on wifi. This issue happens only in Swaziland and no where else.
Issue,
Even though HttpClient is configured with setAuthenticating as 'True', the client is not responding to 401 challenges for POST requests. But the same works fine for HEAD requests.
Attaching the request logs for both the scenarios.
Help,
We wanted to add some additional logging on the ODK side to log all the requests and responses.
Tried to follow this, but couldn't get it to work:
http://stackoverflow.com/questions/3246792/how-to-enable-logging-for-apache-commons-httpclient-on-android/3303131#3303131
Any help will be appreciated!
-Shruthi
logs.txt (3.17 KB)
What Android OS are you using?
Is this using both ODK Collect and ODK Aggregate? What versions of each?
In the success case, your phone should only be issuing at most 2 HEAD
requests,
HEAD -- no authentication -- returns 401
HEAD -- with authentication -- returns 204
then, a single POST with authentication, returning 201
It looks like there are two simultaneous attempts to send data to the
server running at the same time. This may be the root cause of
http://code.google.com/p/opendatakit/issues/detail?id=692
where else.
Issue,
Help,
-Shruthi
