i need to learn to write a syntax to sum/count selected options from a question that has four option. i can calculate that of yes/no but not when it's more than two.
Welcome to the ODK forum, @A_JOSEPH_ENNE ! We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a picture as your avatar because it helps build community!
Can you please share the question text and the options? It will help in understanding your question.
thank you so much.
i will do the introduction as mentioned and will add the photo. my crucial question is this: i have a couple of questions with responses like these:
- 90% and above
- Between 50% and 90%
- Between 25% and 50%
- Less than 25%
what i need is this: i should have a field with summation of each of these responses when selected as an option. in this care, if option is selected in 4 of the question, i should have a field that will sum(count) and display the '4' for me, like wise the option 2, 3 , and 4.
thank you
Here is an example using the if() expression.
counting_answers_example.xlsx (10.0 KB)
