How can we edit the submission of an encrypted project?
I need to edit submissions on a form that is encrypted.
Hello @Nayana_Balan
Whenever you will get time please Introduce yourself Here
Elaborating on your question with more details makes it easier for others to assist you. Next time, simply respond to the question prompts when posting.
Submission encryption is for contexts where you don't trust your server or you absolutely need to guarantee that the data is only accessible to a set number of individuals. Generally when those are true, ODK Central is only used for initial data capture and then the data is stored somewhere else trusted for further work. That's where you would do your edits rather than within Central.
If you feel like you'd like both submission encryption and Central-based edits, please let us know a little bit about your context and needs.
