Hi Community
I try to run the attached XlsForm example, but i got this error:
08-06 14:31:06.392: E/MessageQueue-JNI(1098): Exception in MessageQueue
callback: handleReceiveCallback
08-06 14:31:06.452: E/MessageQueue-JNI(1098):
org.javarosa.core.log.WrappedException: Error evaluating
/breakRepeat/miembros/BREAK0:
org.javarosa.xpath.XPathTypeMismatchException: XPath evaluation: type
mismatch nodeset has more than one node[/breakRepeat/miembros[1]/cuerpo[1]/BREAK1[1];/breakRepeat/miembros[2]/cuerpo[1]/BREAK1[1]];
cannot convert to value =>
org.javarosa.xpath.XPathTypeMismatchException[XPath evaluation: type
cannot convert to value]
08-06 14:31:06.452: E/MessageQueue-JNI(1098): at
org.javarosa.core.model.FormDef.evaluateTriggerable(FormDef.java:712)
Thanks for any help
breakRepeat.xls (29 KB)
Please send questions to ONLY ONE e-mail group.
Sending to multiple groups just annoys the people who are most likely to
reply (I have 3 copies of this question... annoyed!)
I've created an issue for this:
http://code.google.com/p/opendatakit/issues/detail?id=884
I believe this should work. However, your usage of indexed-repeat() is
unexpected.
indexed-repeat() is intended for referencing the values of a different
repeat group -- one that the form field using indexed-repeat is not itself
contained within.
On Tue, Aug 6, 2013 at 7:42 AM, Ramon de la Cruz Lazaro <rmdlazaro@gmail.com wrote:
Hi Community
Thanks for any help
Thanks for responding quickly.
Sorry for posting three times.
I have not been able to implement a repeat break with custom message. I
always get errors.
Is there any way to implement it without using indexed-repeat() ?
2013/8/6 Mitch Sundt
unexpected.
contained within.
On Tue, Aug 6, 2013 at 7:42 AM, Ramon de la Cruz Lazaro < rmdlazaro@gmail.com> wrote:
Hi Community
Thanks for any help
https://groups.google.com/d/topic/opendatakit/IQLreLXRMZs/unsubscribe.
Atte
Ramón De la Cruz L.
Ramon,
Your BREAK0 field references BREAK1, which is inside a group that has its
relevance controlled by BREAK0. This would seem to be a logical conundrum.
I'm not sure that a group within a repeat can have a relevance that's based
on a calculated field within the repeat. More broadly, I'm not sure that
it's possible to accomplish what you seem to be trying to accomplish: have
a repeating group that continues repeating until some dynamic condition is
met (i.e., until within-repeat fields satisfy some condition).
Your two primary choices for repeat groups are:
Specify a repeat-count based on some prior fields, and the repeat group
will repeat exactly that number of times.
Or, do not specify a repeat-count, in which case the pop-up prompt will
ask whether to add new instances.
Maybe somebody else has a clever third option?
Chris
On Tue, Aug 6, 2013 at 7:47 PM, Ramon de la Cruz Lazaro <rmdlazaro@gmail.com wrote:
always get errors.
2013/8/6 Mitch Sundt mitchellsundt@gmail.com
unexpected.
contained within.
Hi Community
Thanks for any help
Atte
Ramón De la Cruz L.
I prefer the second alternative. But how do I leave the repeat group with a
select_one yes_no; without displaying the default pop-up prompt.
I think, it could create a select_one with appearance = "break Y N" (or
"break 1 0", "break 1 2")
Y) break the repeat group
N) continue the next iteration
Ramon
2013/8/6 Christopher Robert
Ramon,
Chris
On Tue, Aug 6, 2013 at 7:47 PM, Ramon de la Cruz Lazaro < rmdlazaro@gmail.com> wrote:
always get errors.
unexpected.
contained within.
Hi Community
Thanks for any help
Atte
Ramón De la Cruz L.
Atte
Ramón De la Cruz L.
To my knowledge, this is not possible.
Creating another repeat group is not something under the control of the
form definition, other than setting an overall maximum number of repeats.
On Thu, Aug 8, 2013 at 9:50 AM, Ramon de la Cruz Lazaro <rmdlazaro@gmail.com wrote:
a select_one yes_no; without displaying the default pop-up prompt.
Ramon
2013/8/6 Christopher Robert crobert@surveycto.com
Ramon,
group will repeat exactly that number of times.
will ask whether to add new instances.
Chris
always get errors.
to reply (I have 3 copies of this question... annoyed!)
unexpected.
contained within.
Hi Community
MessageQueue callback: handleReceiveCallback
Thanks for any help
Atte
Ramón De la Cruz L.
Atte
Ramón De la Cruz L.
