Would Appreciate If i get a comprehensive step-by-step tutorial on how to
create a form using ODK Build.Especially fields with alphanumeric values.
Please review http://opendatakit.org/use and
http://opendatakit.org/help/training-guides.
-- Need ODK help? Go to http://nafundi.com for custom features, form design, implementation support, and user training for ODK.On Wed, May 8, 2013 at 7:59 PM, teachMe learnapps2013@gmail.com wrote:
create a form using ODK Build.Especially fields with alphanumeric values.--
Thanks Yaw for the response,but i discovered that i'm limited to 9-digits
in the numeric field when entering data on my android device even though i
didn't enable the range checkbox while designing the forms Using ODK
Build.What could be the problem and how could it be solved?
On Thursday, May 9, 2013 3:59:26 AM UTC+1, teachMe wrote: > > Would Appreciate If i get a comprehensive step-by-step tutorial on how to > create a form using ODK Build.Especially fields with alphanumeric values. >As previously discussed in the ODK Community group:
According to the notes in the ODK Collect code:
"// ints can only hold 2,147,483,648. we allow 999,999,999"
The 9 digit limit appears to prevent people from putting too large of
number in the input. Because of historical computer design reasons an
Integer in Java must be smaller than 2,147,483,648. There are
different number types that can support larger values but that will
require a lot of changes.
May I suggest using a string instead?
Additionally, you can use a string with a appearance="number" and it will
let you only input numbers, but up to the length of a string.
Hope this helps,
Waylon
On Fri, May 10, 2013 at 12:30 AM, teachMe wrote:Thanks Yaw for the response,but i discovered that i'm limited to 9-digits
Build.What could be the problem and how could it be solved?On Thursday, May 9, 2013 3:59:26 AM UTC+1, teachMe wrote:
Thanks Waylon,would try it out
On Fri, May 10, 2013 at 9:00 AM, W. Brunette wrote:As previously discussed in the ODK Community group:
require a lot of changes.May I suggest using a string instead?
let you only input numbers, but up to the length of a string.Hope this helps,
WaylonOn Fri, May 10, 2013 at 12:30 AM, teachMe learnapps2013@gmail.com wrote:
to create a form using ODK Build.Especially fields with alphanumeric values.--
