How do I create Assign Local Government Areas to States for Example FCT state has Abaji,AMAC,Kwale LGAS while Oy
I have list of States with different LGAs for Example FCT State has Bwari,AMAC, Kwali,Kuje LGAs while OYO state has Atiba,Lagelu,Akinyelye etc LGA.If OYO state is selected,only Atiba,Lagelu,Akinyelye etc should come up.If FCT state is selected, only Bwari,AMAC, Kwali,Kuje LGAs should be displayed
2. What app or server are you using and on what device and operating system? Include version numbers. I am using ODK build, to be deployed on Android
3. What you have you tried to fix the problem? Nothing
4. What steps can we take to reproduce the problem? How to implement it
5. Anything else we should know or have? If you have a test form or screenshots or logs, attach below. Nothing
Hi @mankind5050
I think you just need to use cascading selects please check it out http://xlsform.org/en/#cascading-selects
https://docs.google.com/spreadsheets/d/1CCjRRHCyJXaSEBHPjMWrGotnORR4BI49PoON6qK01BE/edit#gid=0
