1. want to only select the household head only once in the Repeat Group loop.
2. ODK Collect v1.2.7..
see the attached excel file..hh_limittion.xlsx (10.9 KB)
any help will be welcome..thanks in advance
Use this constraint if(${position}=1,.=1,.>1) on relationship row. Basically this constraint force to select hh head in the first repeat.You could modify the constraint.
Do not forget to put a constraint message or hint for user.
Check an example XLSForm for reference select_hh_head_once.xlsx (15.1 KB) .
There may have alternative soultion but for now you can use it.
thanks works fine @ARIF_AZAD_KHAN..I appreciate
is there a way not to limit the selection of household head to be the first, but can not be repeated
how do i remove the force for the household head from the first repeat.?
