How do we set a number for Correct Choice and then collect those correct numbers?
Are you asking about a way to use a survey as a test and calculate a score inside the form?
Yes We want to Take a Test and in the end it must show the result.
You can use a followup calculate question for each question the user answers that evaluates to "1" if correct. And then use a final calculate question to get the percent correct.
if(${test_question_1} = 'correctAnswer1', 1, 0 )
if(${test_question_2} = 'correctAnswer2', 1, 0 )
( (${test_question_1} + ${test_question_2}) / 2 ) * 100
- this uses the
if(...)
function - you can also use
round(...)
in your final calculation to return a number with a specific number of decimal places
