we installed our own ODKAggregate (RC2) server with Tomcat and
PostgreSQL under WIN7 OS. We use the ODK Collect v1.1.7-RC1.apk on the
mobile side. Everything works fine (except for the csv export).
Now we have some questions on how we can access the data with our own
programs.
How does ODKAggregate and PostgreSQL store images? How can we access
them?
Is there any chance to access them via the file system?
If PostgreSQL stores them as BLOBs, how can we export them from the
database?
Can you file an issue on the ODK google code site describing you issue
with csv export?
On Wed, Oct 5, 2011 at 7:34 AM, LETSGO CeLeKT wrote:
> Hi,
> programs.
> them?
> database?
> Thanks for your support!
them?
binary data are stored as blobs. the most user-friendly way to extract
them is to use odk briefcase
(http://code.google.com/p/opendatakit/downloads/list). export to csv
will only give you urls to
the binary files.
currently, no.
database?
if you want to access them programmatically, you'll have to write code
to do that. use odk briefcase if you just want to dump the data.
programs.
them?
database?
Also, the new breifcase application scheduled to be released later
today (U.S. pacific time) will extract your binary data from
Aggregate.
Cheers,
Waylon
> with csv export?
>> Hi,
>> programs.
>> them?
>> database?
To further add on, Aggregate exposes the image via the web so you can
grab the data from that link if you want to write a script instead of
writing a SQL statement for postgres.
Waylon
>> them?
> the binary files.
> currently, no.
>> database?
I reported the csv error on the Google Code site (issue 359).
Thank your replying so quickly, I will have a look at ODK Briefcase.
And I will come back to you if we have any problems with the SQL
queries.
BTW How would a MySQL Database store the images?
> Waylon
> >> them?
> > the binary files.
> > currently, no.
> >> database?
> queries.
>> Waylon
>> >> them?
>> > the binary files.
>> > currently, no.
>> >> database?
them?
the binary files.
currently, no.
database?
