I'm sorry for posting so many questions here on the forum.
Regarding select_one questions, Constraint:
not(selected(.,'B02'))
This 'constraint' will display an error when optionName B02 is selected.
This always happens when I am trying out validation on my forms. I am always confused on how Constraint really works.
Are conditions placed on contraint need to be what should not happen, or what should happen?
I have two select_one questions.
Q1 has 9 options
Q2 has 10 options
What I want to happen, is While Q1=opt 1-6 selected, and Q2=opt 2 selected, there would be an error.
I am using XLSForm Viewer to test the form: https://getodk.org/xlsform/
I have searched "Constraint on Select_one" on the net and this forum multiple times, but I have yet to find a solution to my problem.
- I first tried isolating the conditions, from which When Q1 opt 1-6 is selected it would display an error
not(.='A00' or .='A01' or .='A02' or .='A03' or .='A04' or .='A05' or .='A06')
- Then when Q2 opt 2 is selected, it would also display an error.
- I tried combining the two:
not(selected(.,'B02') and .='A00' or .='A01' or .='A02' or .='A03' or .='A04' or .='A05' or .='A06' )
But then Q2 doesnt display errors
- Tried just separating them
not(selected(.,'B02')) and not(.='A00' or .='A01' or .='A02' or .='A03' or .='A04' or .='A05' or .='A06')
But then Q2 will always display error when opt 2 is selected.
ODK Tester (43).xlsx (39.0 KB)
