others to spreadsheets; but in both cases, I don't know the wau to access
each set of these published data.
Your help, please.
Regards.
coliasso,
When you publish to Goodle Fusion Tables, a popup will prompt you to supply
an email address for the person that will have access to the data. Put your
email address there. Then, check your email and you will have an email with
a link to the Google Fusion Table.
Let me know what you think,
Jefferson
On Tuesday, June 28, 2016 at 6:38:52 PM UTC-6, coliasso wrote: > > Hi, > From my ODK Aggregate server, I've published some data to Fusion Tables > and others to spreadsheets; but in both cases, I don't know the wau to > access each set of these published data. > Your help, please. > Regards. >Jefferson, many thanks for suggestion.
After putting my email address in that field, I have received any eamil
from The Google Fusion Table; then, contnuing my research on my ODK
Aggregate web page, I went into the Form management menu, after in its
sub-menu named "Published data"; there, I've seen a coloumn named "Name"
which values are " View Main Fusion Table"; clicking on any of them put me
to the concerned published table.
Regards
Le mercredi 29 juin 2016 03:54:05 UTC+2, Jefferson Francisco a écrit : > > coliasso, > > When you publish to Goodle Fusion Tables, a popup will prompt you to > supply an email address for the person that will have access to the data. > Put your email address there. Then, check your email and you will have an > email with a link to the Google Fusion Table. > > Let me know what you think, > > Jefferson > > > > On Tuesday, June 28, 2016 at 6:38:52 PM UTC-6, coliasso wrote: >> >> Hi, >> From my ODK Aggregate server, I've published some data to Fusion Tables >> and others to spreadsheets; but in both cases, I don't know the wau to >> access each set of these published data. >> Your help, please. >> Regards. >> >Ccoliasso,
If you are still having this problem, stop publishing, and try again
with a Gmail account. You won't get an email from Google, but the
table will shop up at https://drive.google.com.
-- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.On Thu, Jun 30, 2016 at 12:29 AM, coliasso altessedac@gmail.com wrote:
After putting my email address in that field, I have received any eamil from
The Google Fusion Table; then, contnuing my research on my ODK Aggregate web
page, I went into the Form management menu, after in its sub-menu named
"Published data"; there, I've seen a coloumn named "Name" which values are "
View Main Fusion Table"; clicking on any of them put me to the concerned
published table.
RegardsLe mercredi 29 juin 2016 03:54:05 UTC+2, Jefferson Francisco a écrit :
coliasso,
email with a link to the Google Fusion Table.Let me know what you think,
Jefferson
Your help, please.
Regards.--
Thanks, Yaw.
Is that means that, all data sent to an ODK Aggregate server is
automatically shared on Google drive?
Le vendredi 12 août 2016 16:31:27 UTC+2, Yaw Anokwa a écrit : > > Ccoliasso, > > If you are still having this problem, stop publishing, and try again > with a Gmail account. You won't get an email from Google, but the > table will shop up at https://drive.google.com. > > Yaw > -- > Need ODK consultants? Nafundi provides form design, server setup, > in-field training, and software development for ODK. Go to > https://nafundi.com to get started. > > On Thu, Jun 30, 2016 at 12:29 AM, coliasso <altes...@gmail.com > wrote: > > Jefferson, many thanks for suggestion. > > After putting my email address in that field, I have received any eamil > from > > The Google Fusion Table; then, contnuing my research on my ODK Aggregate > web > > page, I went into the Form management menu, after in its sub-menu named > > "Published data"; there, I've seen a coloumn named "Name" which values > are " > > View Main Fusion Table"; clicking on any of them put me to the > concerned > > published table. > > Regards > > > > > > Le mercredi 29 juin 2016 03:54:05 UTC+2, Jefferson Francisco a écrit : > >> > >> coliasso, > >> > >> When you publish to Goodle Fusion Tables, a popup will prompt you to > >> supply an email address for the person that will have access to the > data. > >> Put your email address there. Then, check your email and you will have > an > >> email with a link to the Google Fusion Table. > >> > >> Let me know what you think, > >> > >> Jefferson > >> > >> > >> > >> On Tuesday, June 28, 2016 at 6:38:52 PM UTC-6, coliasso wrote: > >>> > >>> Hi, > >>> From my ODK Aggregate server, I've published some data to Fusion > Tables > >>> and others to spreadsheets; but in both cases, I don't know the wau to > >>> access each set of these published data. > >>> Your help, please. > >>> Regards. > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google > Groups > > "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send > an > > email to opendatakit...@googlegroups.com . > > For more options, visit https://groups.google.com/d/optout. >Amal,
It's not automatic. If you choose to stream data from Aggregate to
Google Fusion Table or Google Spreadsheets, that data will appear in
your Google Drive list.
-- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.On Mon, Aug 15, 2016 at 3:53 PM, Amal altessedac@gmail.com wrote:
Thanks, Yaw.
Best,Le vendredi 12 août 2016 16:31:27 UTC+2, Yaw Anokwa a écrit :
Ccoliasso,
table will shop up at https://drive.google.com.Yaw
https://nafundi.com to get started.On Thu, Jun 30, 2016 at 12:29 AM, coliasso altes...@gmail.com wrote:
from
web
are "
concerned
published table.
coliasso,
data.
an
Jefferson
Tables
Your help, please.
Regards.--
Groups
an
Thanks, Yaw.
Best.
