How to access Entity Tables from OData feed from Power BI
I am trying to read the Entity Data from ODK-Central using the Power BI OData feed. Can someone help me with the OData endpoint for this?
I tried "{url}/v1/projects/{id}/datasets/" "{url}/v1/projects/{id}/datasets/{tablename}" and ""{url}/v1/projects/{id}/datasets/{tablename}/entities". None of these worked.
Hi @Debjit_Biswas1
Are you using ".svc" (extension) at the end of the {tablename}? :thinking:
{tablename}.svc - this way..
Thank you @MinimalPotato !
Got that working.
