I got started with ODK Build and have a reasonable form going. They I
noticed that there were additional widgets on offer - and am now wondering
if there is any documentation as to how to properly add those? I took the
xml from build and tried to do it manually for the Trigger widget:
<h:body>
acknowledge widget
need to push button
</h:body>
From what I could see, there are three parts to the xml: the instance, the
bind and the body. I inserted the parts of the widget xml into those spots
and ten tried to upload a new form directly into Aggregate - to get the
dreaded form of death:
AppEngine Application Problem
A problem has occurred that prevents your AppEngine application from
responding.
So - is there any instruction for doing this, of can anyone point me in the
right direction for properly adding a widget?
Allister
Need ODK help? Go to http://nafundi.com for custom development,
professional support, form design, implementation advice, and user
training for ODK.
I got started with ODK Build and have a reasonable form going. They I noticed that there were additional widgets on offer - and am now wondering if there is any documentation as to how to properly add those? I took the xml from build and tried to do it manually for the Trigger widget:
<h:body>
acknowledge widget
need to push button
</h:body>
From what I could see, there are three parts to the xml: the instance, the bind and the body. I inserted the parts of the widget xml into those spots and ten tried to upload a new form directly into Aggregate - to get the dreaded form of death:
A problem has occurred that prevents your AppEngine application from responding.
So - is there any instruction for doing this, of can anyone point me in the right direction for properly adding a widget?
Allister
