How to add two weeks to the current date
Dear all,Please I am a novice to ODK. Currently I'm working on a
questionnaire and I have reached a place where I suppose to add two weeks
to the current date.How Could I do it?
with the newest ODK Collect 1.4, you can do
calculate="date-time(decimal-date-time(${dateField})+14)"
Note that there are several issues with preserving the time portion of a
date during calculations like this, so you may or may not be able to
preserve the time-of-day.
In the above, I mean put the
in the 'calculation' column of the XLSForm.
I was mixing the constructions in the XML and XLS
Dear esteemed
I am working on an ODK XLS form and I wish to calculate the difference between two datefields and then divide by 7.
I would love the answer to be rounded up
In excel it would look like this (x1-x2)/7.
The idea is to get the number of weeks.
Kindly help.thanks
Date arithmetic in ODK Collect has several bugs that can lead to off-by-one
errors (particularly when working in different time zones or transitioning
between daylight savings time and standard time); time arithmetic is even
less certain.
Be sure to test your form to make sure it works as you expect.
That said, there are a number of functions for date arithmetic. See:
in particular, "date, dateTime, time as number"
··· On Fri, Apr 3, 2015 at 2:03 AM, wrote:
Dear esteemed
Kindly help.thanks
Dear all,
I want to define between 2010-01-01 and current date . How can design in odk excel. Pleases! help
Do you want to restrict to put dates between the dates you mentioned? If so you can check the discussion Constraint on date - #3 by Fula
