hi,
i will create some integer questions. i want total acres is autofill the total_C response.
can this possible.
hi,
can this possible.
can this possible Total_Acres auto-fill.
for example: (2018 in 10) or (2019 in 5) and (2020 in 5) the total is 20, 20 is auto-fill in Total Acres.
Hi @aftab01
A warm welcome to the GetODk community, when you get a chance please introduce yourself
Yes, it is possible, you have to make use of the form operator functions, in this particular case the addition function. In your Total_Acres variables please add C11-C13, the field values will be ${C11} + ${C12} + ${C13}
You can read more in the documentation
please see the link
first of all thank for quick reply.
but my question is can i show this total in total acres question.
Hi @aftab01
Yes, you can show the total, you need a variable to hold the calculation and another variable to display the result. See documentation
result show in calculation question, but i need the result in integer question.
the total acres question after showing the integer 2020 question.
HI @aftab01
You can hide the calculation and display the result in the integer 2020 question.
Are you in a position to share your form?
Agri - sample.xlsx (13.6 KB)
see the sample file
Hi @aftab01
Please find attached simplified sample working form
Agri_sample_ronald.xlsx (7.1 KB)
can i put a error massage in note question.
Hi @aftab01
You can use the constraint and constraint_message feature to validate responses and show error messages.
