How to compile geoodk on android studio
hello everyone,
i am trying to clone the geoodk i downloaded from github but am having problem in running the app on emulator.
the error message is collect-master\app\build\intermediates\merged_manifests\debug\AndroidManifest.xml:140: error: unexpected element found in .
Hi @ogunmolu1960. GeoODK isn't a core ODK tool. It's a fork of ODK Collect and it's unmaintained and a year or two out of date.
If you'd like help with it, ask at https://groups.google.com/forum/#!forum/geoodk-developers, but again, it's unmaintained so you might not get a response.
thank you very much Yanokwa. I dont know if there is any data collection app better or almost equal for field data collection with spatial that i can use mbtiles as layer.
May God bless you.
Core ODK Collect does allow you to set offline map layers with raster mbtiles: https://docs.opendatakit.org/collect-offline-maps/ You will also soon be able to set offline map layers from vector mbtiles (see Geo: Using the Mapbox SDK for Android).
