I have installed the VM in Virtualbox,i wish to connect to mysql and export data and images into another application,how do i connect to mysql in the vm.
2.how to phpmyadmin in the vm,
thanks
thanks
Hi there,
If the goal is to get the data and images, the simplest option is to
install ODK Briefcase (https://opendatakit.org/use/briefcase/) and
that will let you download all the data and images.
If you need access to the underlying database, the server is a
standard Ubuntu machine. You can login with root credentials (see the
readme) and install and run whatever software you'd like on it.
