@Grzesiek2010
how can i add constraint/validation on calculate field...
i want to restrict interviewer who are getting 1 in calculate field
ODk Collect , ODK Aggregate
i have tried ".=1" without quotation in constraint field of calculate
When you generate the result mid of the survey or end of the survey? Restrict mean stop interviewing and end the survey? It would be better if you attach XLSForm here explaining little bit more.
i want to restrict interviewer to go next who have response 1 in return..
If options for that particular question are 1 2 3 4 5 etc then put constraint .>1.
Constraint is used with questions not calculations so if it's a result of a calculation you might want to pass it to a question first.
could you please provide some sample file plz..
This for example: constraintTest.xlsx (5.3 KB)
The enclosed example may be useful in that (unlike the previous one above) it prevents the user from advancing through the form unless the constraint is met.
In the example above, a note is displayed if the constraint is not met, but the user can continue to marcht through the form and submit it even if the constraint continues not to be met.ExampleHardConstraint.xlsx (11.1 KB)
