We're using ODK Collect 1.4.5 on Nexus 7 tablets
We've unchecked "Delete after send" + "Delete Saved Form" (hide from Main Menu) under Admin but we're still experiencing that the finalized form is deleted from the tablet after sending (we changed the view to see Sent and Unsent so can see it was sent)
Thank you
After the form is successfully sent, it is removed from the Edit Saved
Forms screen, and is therefore never allowed to be re-opened and edited.
The removal from that screen does not mean that the filled-in form has been
deleted from the device.
If you can see it in the Send Finalized Form / Sent and Unsent listing,
that means that the filled-in form is still on your device.
Checking the "Delete after Send" checkbox causes the filled-in form to be
removed after it is successfully sent, and the filled-in form would then
not appear in the Send Finalized Form / Sent and Unsent listing and would
not appear on the Delete Saved Form / Saved Forms screen.
On Thu, May 28, 2015 at 1:08 PM, jmlimuh via ODK Community < opendatakit@googlegroups.com> wrote:
Thank you
