I took a quick look at the files and it confirms what I described earlier.
Dear Yaw,
Many thanks for your prompt response. I am responding on behalf of
Genevieve, as she is currently travelling.
I am attaching here the XLS and converted XLM files for a short
questionnaire with a couple questions in Sinhala (label in English, hint
has
the translated question in Sinhala, and then the response options
translated
in the second sheet in column E). The Sinhala shows up properly in
Excel,
but not on the tablet. Also, on the tablet I installed a MultiLing App
and
Sinhala Plugin from Google Play, so I can type Sinhala into the tablet,
but
when I send this data to Aggregate in the cloud, and export, the Sinhala
font is not preserved. See attached a CSV file showing how the Sinhala
comes
up.
We are using Asus Fonepads, Android V4.3. I have also attached the
Sinhala
font we are using, which displays clearly in Word and Excel.
Any advice or assistance you could provide would be greatly appreciated.
Many thanks,
Kelsi
Groups
an
Kelsi Kriitmaa
Director
KRIITMAA CONSULTING
Italy: +39 389 928 0079
Kenya: +254 (0) 729 330 690
Canada: +1 250 859 8417
skype: kelsi.kriitmaa
website: www.kriitmaa.com
On Aug 15, 2014, at 3:57 PM, Yaw Anokwa yan...@nafundi.com wrote:
Hi Geneviève,
Collect can only display what Android enables it to display. My guess
is that you are using an old version of Android or your device doesn't
support Sinhala natively (e.g., without rooting and adding special
files). If you'd like me to confirm, send out a small one question
form that has some Sinhala and I can test on my devices. You can also
try to view Sinhala websites and confirm if those work.
You can certainly try to root the device and install custom fonts, but
that's a process that requires a fair bit of technical skill. See
http://blog.malinthe.com/2014/04/how-to-get-perfect-sinhala-text-on-android-4-4-kitkat/
for a rough overview. Your best alternative is to use image-based
forms as described at http://opendatakit.org/help/image-based-forms
Good luck,
On Fri, Aug 15, 2014 at 4:43 AM, geneviev...@gmail.com wrote:
Dear all,
We are trying to display a survey in Sinhal and English on ODK collect.
Without surprise, displaying the questions in English is not a problem,
but
we can't display the questions in Sinhal. Because we have the fonts on
our
computer we do not have a problem displaying the questions in excel.
What are the required steps to display it properly in ODK collect?
- How to save and validate the .xls form
- How to enable the tablet to recognise the font.
Thank you for your help!
Kind regards,
Geneviève
Groups
an
