I'm fairly new to xforms, and have looked at http://opendatakit.org/help/form-design/binding/. Now I am trying to
achieve the following:
I have a repeated group of fields, and in one of the hints, I want to
display the current index of the repetition; for example, like "You are now
entering the 4th product" if he has about to enter the 4th 'instance' of
this repeated group.
My idea was to do it as below, but it doesn't seem to be correct (in the
output, I only see "You are entering the" and nothing afterwards, but also
no exception). Not sure if I'm using the function correctly and at the
right place. You are entering the .
product
PART 1: PRODUCTION STATUS
1.2 Production status details
* You are entering the .
product*
Product reference:
Number of closed cartons:
Quantity of packed products:
Quantity of finished but unpacked products:
Quantity of unfinished products:
I think your usage is correct, but this must be a bug in the JavaROSA
library. My guess is that count() isn't implemented properly. Anyway,
I'll forward this on to the javarosa-developers list and try to track
it down. I've filed the bug at http://code.google.com/p/opendatakit/issues/detail?id=539 for now.
> http://opendatakit.org/help/form-design/binding/. Now I am trying to achieve
> the following:
> no exception). Not sure if I'm using the function correctly and at the right
> place.
> product
> This is my repeating field section in my form:
> Product
> product
> Product reference:
Actually I saw that I made one mistake, which results to a different
output, however, there still seems to be a bug with the count.
First, my correction: there should be a /repeatingFieldList in the path.
You are entering the . product
This leads then to an output of:
*"You are entering the 1. product" *
but remains at 1, even I'm already entering the second or third instance
of it. It seems that the count() doesn't work properly/can't be used with a
variable that refers to itself (meaning: while I'm in repeatingFieldList, I
can't use count on any field within repeatingFieldList).
However, when I refer to a different variable in the count method, for
example to a previous repeating field list (not the current one), I'm
getting the correct (final) number of instances of that repeated field list.
On the other hand, the counter (but I guess it's not using the count()
method of xforms here) in the 'breadcrumb path' that's automatically
displayed by ODK is fine.
See the following screenshot (the second red-marked number should also be a
3, but it's always showing a 1):
(I will add this finding to the bug report).
Mathias
On Sun, Mar 18, 2012 at 1:29 PM, Yaw Anokwa wrote:
Hi Mathias,
achieve
the following:
now
also
right
place.
product
product
Product reference:
The reason this is occurring is because in JR, the evaluation context for
relative references inside a repeat is evaluated against the current
nodeset (inside the repeat). This is necessary for constructs like
The answer to the previous question was
to work correctly.
count() in this context would also only return the correct value for the
last element. The xpath function which does the best thing here is
position(), which is supported in the newest code for JR, which is
currently staged and working at our fork ( http://bitbucket.org/commcare/javarosa), and will be pushed back into the
core JR libraries soon.
-Clayton
On Sun, Mar 18, 2012 at 3:27 AM, Mathias Lin wrote:
Hi Yaw,
thanks for the reply and filing the bug report.
instance of it. It seems that the count() doesn't work properly/can't be
used with a variable that refers to itself (meaning: while I'm in
repeatingFieldList, I can't use count on any field within
a 3, but it's always showing a 1):
On Sun, Mar 18, 2012 at 1:29 PM, Yaw Anokwa yanokwa@gmail.com wrote:
Hi Mathias,
achieve
the following:
now
also
right
place.
product
Another option is to use "new-style" repeats that are in the JavaROSA,
but have not been enabled in Collect UI. Those repeats should enable
you reference the variables $i and $n for the current index and total
of repetitions, respectively. Drew from Dimagi is the expert on
It shouldn't be too much work to turn them on, and the addition would
be a nice win for the ODK community.
On Mon, Mar 19, 2012 at 08:10, Clayton Sims wrote:
> Mathias,
> relative references inside a repeat is evaluated against the current nodeset
> The answer to the previous question was value="count(/nm/repeatingFieldList/previous)"/>
> to work correctly.
> is position(), which is supported in the newest code for JR, which is
> (http://bitbucket.org/commcare/javarosa), and will be pushed back into the
> -Clayton
>> Hi Yaw,
>> You are entering the > value="count(/nm/repeatingFieldList/output1_2)"/>. product
>> http://imageshack.us/photo/my-images/838/odkrepeat.png/
>> - Mathias
>>> Hi Mathias,
>>> Yaw
>>> > achieve
>>> > the following:
>>> > now
>>> > of
>>> > the
>>> > also
>>> > right
>>> > place.
>>> > product
>>> > Product
>>> > You are entering the >> > value="count(/nm/output1_2)"/>.
>>> > product
>>> > Product reference:
Dear Yaw
Could I refer to value of variable when i'm outside of repeats in the next release of Collect? Could you estimate the time for the next release (I read from another topic that this function will include in Collect 1.1.7 but I haven't seen it)?
I'm doing a household research and we need to call out the index number of member in household from outside of repeats to enter more details.
Thank you
Quang
Vào 02:33:27 UTC+7 Thứ bảy, ngày 24 tháng ba năm 2012, Yaw Anokwa đã viết:
> Mathais,
> # of repetitions, respectively. Drew from Dimagi is the expert on
> this, so you can follow up with him at
> https://groups.google.com/group/javarosa-developers/browse_thread/thread/1e1e3681580a407a.
> Yaw
> > Mathias,
> > The answer to the previous question was > value="count(/nm/repeatingFieldList/previous)"/>
> > to work correctly.
> > -Clayton
> >> Hi Yaw,
> >> You are entering the >> value="count(/nm/repeatingFieldList/output1_2)"/>. product
> >> - Mathias
> >>> Hi Mathias,
> >>> Yaw
> >>> > achieve
> >>> > the following:
> >>> > now
> >>> > of
> >>> > the
> >>> > also
> >>> > right
> >>> > place.
> >>> > product
> >>> > Product
> >>> > You are entering the >>> > value="count(/nm/output1_2)"/>.
> >>> > product
> >>> > Product reference:
On Wed, Mar 28, 2012 at 11:30, wrote:
> Dear Yaw
> Thank you
> Quang
>> Mathais,
>> Yaw
>> > Mathias,
>> > The answer to the previous question was > > value="count(/nm/repeatingFieldList/previous)"/>
>> > to work correctly.
>> > -Clayton
>> >> Hi Yaw,
>> >> You are entering the > >> value="count(/nm/repeatingFieldList/output1_2)"/>. product
>> >> - Mathias
>> >>> Hi Mathias,
>> >>> Yaw
>> >>> > achieve
>> >>> > the following:
>> >>> > now
>> >>> > of
>> >>> > the
>> >>> > also
>> >>> > right
>> >>> > place.
>> >>> > product
>> >>> > Product
>> >>> > You are entering the > >>> > value="count(/nm/output1_2)"/>.
>> >>> > product
>> >>> > Product reference:
Referring to values outside of a repeat is currently in the core code base
along with predicate support. We still need to plan out the integration of
the new core code into ODK Collect.
-Clayton
On Wed, Mar 28, 2012 at 7:57 PM, Yaw Anokwa wrote:
New style repeats didn't make the cut for 1.1.7, and it's unlikely
they'll make the cut for the next release unless a community member
adds it.
Dear Yaw
Thank you
Quang
viết:
Mathais,
On Mon, Mar 19, 2012 at 08:10, Clayton Sims csims@dimagi.com wrote:
Mathias,
for
nodeset
to work correctly.
the
into the
path.
instance
with a
for
field list.
count()
also be
Hi Mathias,
JavaROSA
Anyway,
track
trying to
achieve
the following:
want to
"You are
now
'instance'
of
(in
the
but
also
at the
right
place.
product
<repeat nodeset="/nm/repeatingFieldList"
appearance="field-list">
<label>Product</label>
product
Product reference:
