I've created a survey using ODK Build and I'd like to upload it to ODK
Aggregate, so that I can access it from my mobile device. What is the
easiest way to do this? (I don't have much coding experience, so a
detailed answer would be much appreciated)
if want to setup a full data collection pipeline, you will need to
setup your own copy of aggregate. we have put instructions at http://code.google.com/p/opendatakit/wiki/GettingStarted which should
help. give those a try and let us know how it goes...
yaw
> Thanks,
> Anoop
Thanks Yaw. I've looked at those pages already and have set up collect
(on an emulator) and aggregate (using the app engine). I'm just stuck
at this step of trying to get my survey from odk build into odk
aggregate. When I select the "export to xml" option in odk build it
gives me the XML code, but I'm not sure how to take it from there and
upload it to odk aggregate.
Anoop
On May 2, 8:52 pm, Yaw Anokwa wrote:
> anoop,
> setup your own copy of aggregate. we have put instructions athttp://code.google.com/p/opendatakit/wiki/GettingStartedwhich should
> yaw
> > Thanks,
> > Anoop
ahh. sorry about that. build is a new tool and we are working to make it better.
for now, when you export to xml, you should copy and paste that text
into a text editor (like http://notepad-plus.sourceforge.net/uk/site.htm). save that file as an
XML file and upload that to aggregate.
i'll file a bug to make this process much easier.
> Anoop
>> anoop,
>> yaw
>> > Thanks,
>> > Anoop
Thanks, that solved the first issue that I was having. Unfortunately,
now my xml file won't upload into ODK aggregate. When I try to upload
the form, I just get sent back to the list of forms and nothing
appears there. This may be an issue specific to problems with my file,
but if you have experienced something similar or know what the problem
might be please let me know. Are there any additional steps I need to
go through to make sure my xml is acceptable/compatible before
uploading it?
Anoop
> into a text editor (likehttp://notepad-plus.sourceforge.net/uk/site.htm). save that file as an
> > Anoop
> >> anoop,
> >> setup your own copy of aggregate. we have put instructions athttp://code.google.com/p/opendatakit/wiki/GettingStartedwhichshould
> >> yaw
> >> > Thanks,
> >> > Anoop
What version of Aggregate are you using? If you attach the form I will be
happy to take a look. The trunk code just changed to check for certain
things. I am interested to know why it's not uploading.
Waylon
uploading it?
better.
setup your own copy of aggregate. we have put instructions athttp:// code.google.com/p/opendatakit/wiki/GettingStartedwhichshould
ODK
the
I'm using Aggregate v0.9.1. Thanks for taking a look, I've emailed you
the file.
Anoop
> Waylon
> > uploading it?
> > Anoop
> > better.
> > > > Anoop
> > > >> anoop,
> > > >> yaw
> > ODK
> > the
> > > >> > Thanks,
> > > >> > Anoop
