I try to run odk build in my local tomcat. So i tried this link
"https://github.com/clint-tseng/odkbuild/blob/master/README.textile". While
i run this line "rake db:dev:start" i am getting
/home/naveen/Desktop/odkbuild-master/Rakefile:80: warning: don't put space
before argument parentheses
/home/naveen/Desktop/odkbuild-master/Rakefile:109: warning: don't put space
/home/naveen/Desktop/odkbuild-master/Rakefile:122: warning: don't put space
/home/naveen/Desktop/odkbuild-master/Rakefile:140: warning: don't put space
Could not find ruby-tokyotyrant-0.5.1 in any of the sources
this error. Could please give me how to slove this error.
Operating System :
Distributor ID: Ubuntu
Description: Ubuntu 12.04.2 LTS
Release: 12.04
Codename: precise
Naveen.
Naveen,
Did you install Tokyo Tyrant? See
https://github.com/clint-tseng/odkbuild/issues/7 for some other ideas.
Operating System :
Release: 12.04
Codename: precise
Naveen.
"ODK Developers" group.
Thanks a lot Yaw Anokwa. Now I try to install ruby-tokyotyrant using "gem
install ruby-tokyotyrant -v 0.5.1". But i am getting following error
Building native extensions. This could take a while...
ERROR: Error installing ruby-tokyotyrant:
ERROR: Failed to build gem native extension.
/usr/bin/ruby1.8 extconf.rb
checking for tcrdbnew() in -ltokyotyrant... no
*** extconf.rb failed ***
Could not create Makefile due to some reason, probably lack of
necessary libraries and/or headers. Check the mkmf.log file for more
details. You may need configuration options.
Provided configuration options:
--with-opt-dir
--without-opt-dir
--with-opt-include
--without-opt-include=${opt-dir}/include
--with-opt-lib
--without-opt-lib=${opt-dir}/lib
--with-make-prog
--without-make-prog
--srcdir=.
--curdir
--ruby=/usr/bin/ruby1.8
--with-tokyo_tyrant-dir
--without-tokyo_tyrant-dir
--with-tokyo_tyrant-include
--without-tokyo_tyrant-include=${tokyo_tyrant-dir}/include
--with-tokyo_tyrant-lib
--without-tokyo_tyrant-lib=${tokyo_tyrant-dir}/lib
--with-libtokyotyrant-dir
--without-libtokyotyrant-dir
--with-libtokyotyrant-include
--without-libtokyotyrant-include=${libtokyotyrant-dir}/include
--with-libtokyotyrant-lib
--without-libtokyotyrant-lib=${libtokyotyrant-dir}/lib
--with-tokyotyrantlib
--without-tokyotyrantlib
extconf.rb:33: shared library 'libtokyotyrant' not found (RuntimeError)
Gem files will remain installed in
/usr/lib/ruby/gems/1.8/gems/ruby-tokyotyrant-0.5.1 for inspection.
Results logged to
/usr/lib/ruby/gems/1.8/gems/ruby-tokyotyrant-0.5.1/ext/gem_make.out
Operating System :
Release: 12.04
Codename: precise
I used this link
http://techblog.ovidiudan.com/2009/05/installing-tokyo-tyrant-on-ubuntu-9.html to
installing Tokyo Tyrant on Ubuntu . After successfull installation of
tokyo cabinet and tokyotyrant, i try to run rake db:dev:start, it comes
with these errors
Run 'bundle install' to install missing gems.
After that i type bundle install in terminal, it says as Gem :: Installer
:: ExtensionBuildError: Error: Failed to build gem native extension and then
An error occured while installing ruby-tokyotyrant (0.5.1), and bundler
cannot continue. Make sure that 'gem install ruby-tokyotyrant -v '0.5.1'
succeeds before bundling.
Could please give me details steps to slove this error.
> Operating System :
> Release: 12.04
> Codename: precise
> Thanks,
> Naveen.
Naveen,
I believe ruby-tokyotyrant is the binding for Ruby to talk to Tokyo
Tyrant. You still need to download and compile Tokyo Tyrant from
source. That is, if you haven't run ./configure, make, and make
install, you probably haven't installed Tokyo Tyrant.
--with-opt-dir
--without-opt-dir
--with-opt-include
--with-opt-lib
--with-make-prog
--without-make-prog
--srcdir=.
--curdir
Results logged to
Operating System :
Release: 12.04
Codename: precise
Naveen,
At this point, not much else I can help with. Perhaps you can search
the web to find help on installing that version of ruby-tokyotyrant.
On Mon, Jul 1, 2013 at 6:59 AM, NAVEENKUMAR G navi.it14@gmail.com wrote:
I used this link
to installing Tokyo Tyrant on Ubuntu . After successfull installation of
with these errors
After that i type bundle install in terminal, it says as Gem :: Installer ::
Operating System :
Release: 12.04
Codename: precise
Naveen.
