Hello,
We are implementing a household survey using ODK in South Sudan and would
like to use the branching feature for some of the questions. For example,
when the enumerator selects the State Name, the following question for
County Name will only list the relevant counties for that state. Once the
county has been selected only the relevant enumeration areas are show on
the next questions and so forth.
The tutorial and widgets don't cover branching. What is the code for
setting this up in an XLS2XForm?
*Mikael L. Clason Hook*
International Consultant, World Bank
US: +1 202.492.0189
South Sudan: +249 956.711.791
Skype: mikaelhook
mhook@worldbank.org
mikaelclasonhook@gmail.com
www.linkedin.com/in/mikaelclasonhook
Mikael,
The tutorial at http://opendatakit.org/help/form-design/xlsform/ has
some information under Skipping Questions.
http://opendatakit.org/help/form-design/binding/ also has some
information on branching (it's called relevance, in XForms lingo).
The easiest way to go is to have a single select one for the states,
and a select one for every state's counties. Then you need to make the
select one for every state's counties relevant if that state has been
selected. That's kind of a mouthful, so here is an example with cars.
select a make
ford
f
honda
h
select a honda model
accord
accord
civic
civic
select a ford model
mustang
mustang
f-150
f150
There are other ways to do what you want (using itemsets), but I think
this is the easiest if you don't have lots of states and counties.
On Fri, Apr 20, 2012 at 07:01, Mikael Clason Hook wrote:
> Hello,
> county has been selected only the relevant enumeration areas are show on the
> The tutorial and widgets don't cover branching. What is the code for setting
> Thanks,
> US: +1 202.492.0189
> Skype: mikaelhook
> mhook@worldbank.org
Mikael,
You can create itemsets, and cascading selections pretty easily in
KoBoForm.
KoBoCollect is based on ODK Collect, with some tweaks for supporting
cascading selections, just as described, for things like State, County,
City.
You can find the KoBoForm Builder at http://www.kobotoolbox.org/koboform/
and you can get some instructions specific to adding datasets for cascading
selections at:
http://www.kobotoolbox.org/support/userguide/koboform/cascadingselect
There is an offline version in case you have bandwidth issues. Please let
us know if it is some help.
☞§※☼:airplane:
~Neil
On Fri, Apr 20, 2012 at 12:20 PM, Yaw Anokwa wrote:
Mikael,
select a make
ford
f
honda
h
accord
accord
civic
civic
select a ford model
mustang
mustang
f-150
f150
On Fri, Apr 20, 2012 at 07:01, Mikael Clason Hook mikaelclasonhook@gmail.com wrote:
Hello,
the
setting
US: +1 202.492.0189
Skype: mikaelhook
mhook@worldbank.org
