I am working on a project using ODK Collect for disease reporting system. I
built the forms and i am able to send the data to the Google Apps Engine.
However, i want to integrate RapidSMS with my ODK project to submit to the
Google Apps Engine.
Is there a means to integrate ODK with RapidSMS , or any hint to merge the
two framework.
Google Apps Engine.
two framework.
I want to have an SMS or client App to make alert to my users on their
mobile phones.
Which way is appropriate - Is there a means to add RapidSMS functionality
into my ODK aggregate
Or Do i need to see other approaches
Thanks In advance,
On Saturday, March 22, 2014 4:29:35 PM UTC+3, Yaw Anokwa wrote:
> Integration means different things to different people. What precisely
> do you want to accomplish?
> Yaw
> Need ODK services? http://nafundi.com provides form design, server
> setup, professional support, and software development for ODK.
> On Sat, Mar 22, 2014 at 5:28 AM, Jona <yonadre...@gmail.com > wrote:
> > Deal All,
> system. I
> Engine.
> the
> > Google Apps Engine.
> the
> > two framework.
> > Regards,
> Groups
> > "ODK Community" group.
> an
If you just want messaging, building something smaller and custom
might be easier. Reach out to the RapidSMS community before you start
coding so they can give you a more up-to-date view of your options.
It's been years since I looked at at stuff.
system. I
Engine.
the
Google Apps Engine.
the
two framework.
Groups
an
I will explore the options that you mentioned , and also i will communicate
the RapidSMS team
Regards,
On Thursday, March 27, 2014 4:23:49 PM UTC+3, Yaw Anokwa wrote:
> Hi Jona,
> There are RapidSMS extensions that give you the ability to send forms
> via SMS. https://github.com/nyaruka/rapidsms-xforms comes to mind.
> Nyaruka also did https://textit.in/ so check that out as well.
> Yaw
> On Thu, Mar 27, 2014 at 1:15 AM, Jona <yonadre...@gmail.com > wrote:
> > Thanks Yaw
> > mobile phones.
> functionality
> > Thanks In advance,
> >> Yaw
> >> On Sat, Mar 22, 2014 at 5:28 AM, Jona wrote:
> >> > Deal All,
> >> > system. I
> >> > Engine.
> to
> >> > the
> >> > Google Apps Engine.
> merge
> >> > the
> >> > two framework.
> >> > Regards,
> >> > Groups
> send
> >> > an
> Groups
> an
