I have changed my data transfer from a POST request to a direct Fusion Table injection, which worked fine.
My main question is how to correctly manage the data transfer options.
I don't mind deleting datastore entities... I see that opendatakit_form_service_cursor_2 has some entities that indicate what data transfer options have been elected for a given form. If I delete the relevant entities, would I break the server? It's very critical that I can manage the data transfer.
I'm using ODK Aggregate v1.4.12 Production hosted on GAE
