I want to modify the filter to work like this:
- Input : a Output : Names starting from a followed by names containing a
- Input : am Output : Names starting with am and folled by names containing am
- Input : amc Output : Names containing amc. (After entering the 3rd alphabet the filtering criteria changes)
All the suggestions in the drop down box should have multiselect property
Mitch_S
#2
If you are drawing the data from a query, on the queries sheet, create an
"order_by" column.
In that column, you should be able to specify:
fieldname ASC
or
fieldname1 ASC, fieldname2 ASC, ...
where fieldname is the name of the field that you want to sort in ascending
order.
names containing a
names containing am
