I cut the formats, F1, F2 etc. To my laptop... But when I want to modified changing some words in the format I require to copy from the laptop to my mobile phone.. Mi cellphone can't recognize F1 for example and the others looks without saving the format
The version is the last and the Sistem is andoid
When I try to edit again on my mobile phone, so I cut from The laptop to my cellphone, but I can't see the File
To copy from my laptop and to see on my cellphone then to edid
Oh no... I think I am dying... Well that form is using GPS to do that I need to travel 4 days and then to go back. This format gave me the company that I was working, I don't know how to explain to them but maybe I can tell them that the app is not perfect.
Hi Nader,
I want to update this case, to the files which has pictures I can read again when I copy from my laptop to my cellphone, the files that has only text they are the problem.
Thank you for your help, I will tell them that adding that I format my mobile phone to new jobs.
Nader,
I just noticed that is in "Español (Perú)", because I am working here with them also the mobile phone is the same.
Do you think everything must be in English, the MTC told me that the installation must be in Spanish because they talking almost Al the time in that language.
Best regards,
Miguel Angel Laura
