I want to multiply some fields inside a repeatable (looped) group and give its answer in a fields which is also inside the same group.
for example, the repeatable group comprises of value1, value2 and product. I want to compute the result of value1 and value2 in the product field.
I have tried using this
calculate="/data/value1 * /data/value2"
in the binding of nodeset product, but its not working.
I want to repeat the group for several values, so I am using repeatable group.
How can I do that?
yanokwa
December 20, 2013, 11:13am
2
The reference should probably be /data/group/value1, not /data/value1.
How can I do that?
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com .
For more options, visit https://groups.google.com/groups/opt_out .
Mitch_S
December 20, 2013, 5:10pm
3
Since this is a repeated group, you likely need to use a relative reference
(assuming the calculate field is within that group)
calculate="../value1 * ../value2"
Note that there are many limitations and problems with repeat groups, and
XLSForm's automatic use of a full path name when referencing a field (
${fieldname} expansion) generally does not work well within repeat groups.
field.
group.
How can I do that?
