How to send form on local ODK Aggregate Virtual Machine
I have installed ODK Aggregate Virtual Machine which is working fine.
I want to send odk form final from my mobile device to ODK Aggregate
Virtual Machine which is on local server. Can anyone please me...
Harish,
Your device and the VM need to be on the same network (e.g., WiFi). Are they?
Once you've done that, follow note 6 in the Notes section of the
readme.txt that comes bundled with the VM.
··· -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
On Fri, Mar 11, 2016 at 8:52 AM, Harish Banaulekar harishbanaulekar10@gmail.com wrote:
I want to send odk form final from my mobile device to ODK Aggregate Virtual
"ODK Developers" group.
Thank you for reply. It's working now..
Hi team
Where can i get the note 6 being reference above
Hi @chamutambara ,
Please note the Aggregate VM and Aggregate server were discontinued and are no longer been supported. If you are starting out please use ODK Central
