Hi all,
I am trying to set up a warning note but not a constraint when a value for something is higher than the value for a previous question. For example if D13_unusedchar is higher than C3_newchar I want a warning note to pop up and say please check and if it is OK they can carry on. Any idea how I do this? I tried
select_one yesno D13_char_check "Note, this is is more than the new charcoal amount left yesterday. Is this right?" ${D13_unusedchar} > C3_newchar
