With the integer type of data when I set 0 by default it appears only 0, but if the type of data is decimal 0 by default turns out to be 0.00000. I would like to have only 0 by default with decimal type of data so the user can add (i.e:) .5 on the right of the digit, or 1 so the final results would be 0.5 or 1. But if the default is 0.00000 the user should delete all the .00000 to add 1 if the answer is 1.
ODK Collect 1.8.1
