Hi everyone, i would like to ask if there is a code on how to set the
default answer of a question in odk.The default answer is from the answer
of the previous question.
Example;
What is the last name of household head?
Ans:lucero
What is the last name of household member 1?
Ans: lucero(default answer from question 1)
Data from previous answers (say Q1) can be used in the same form as
output, but you shouldn't use it to pre-fill a future answer (say Q2)
because the user entered value in Q2 will eventually be replaced if
the user (or app) ever touches the Q1 question.
default answer of a question in odk.The default answer is from the answer of
Example;
Ans:lucero
I'm trying to do exactly what you propose in your scenario, using ${var} in default and 'yes'in read only. However, I do not manage to pull the data (eg. string), instead the answer is exactly ${var}. Any suggestions? What i am trying to do here is to get HH information repeated in a repeat group as for the data to appear as answers in the repeat group.
Any suggestions?
Thanks in advance,
Genevieve
On Wednesday, September 16, 2015 at 2:19:19 PM UTC+2, Yaw Anokwa wrote:
> Hi Ronaldo,
> Yaw
> > Example;
> > 1. What is the last name of household head?
> > Ans:lucero
> > 2. What is the last name of household member 1?
> > Please help me. Thank you.
> > You received this message because you are subscribed to the Google Groups
> > "ODK Community" group.
> > To unsubscribe from this group and stop receiving emails from it, send an
> > email to opendatakit+unsubscribe@googlegroups.com.
If this is still a problem you are having, can you post a small 1-3
question form that shows what you are trying to do and the problem you
have?
On Thu, Sep 22, 2016 at 6:14 PM, genevieve.audet.b@gmail.com wrote:
> Dear Yaw,
> Any suggestions?
> Thanks in advance,
> Genevieve
>> Hi Ronaldo,
>> Yaw
>> > Example;
>> > Ans:lucero
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com.
