How to skip a whole group of questions in ODK Collect?
Hello,
In ODK Build, how do I create a skip logic to skip a whole number of questions (not just one) if the answer to the original question signifies that the next group of qs are not relevant, e.g. "do you have a secondary source of income?" If "yes" there will be a following 5 sub-questions, if "no", it skips these?
Many thanks!
Hi @rose
you need to keep all those question in a group and then you can skip such a group like one single question.
Regards,
Grzegorz
in addition of @Grzesiek2010' s answer, I suggest you to give that group a name and build your skip logic with that name.
Please find out excel form and in this form when you will select yes in first question then that group will run otherwise whole group will skip. Below is example in excel file:
group.xlsx (10.3 KB)
Narendra
@iamnarendrasingh Can you also attach a quick example using ODK Build?
Hi Rose
If we assume that the Q_Sincomesource question name
We are placing this condition in
Relevance
/data/Q_Sincomesource ='yes'
(if using ODK builder)
In the following 5 sub-questions
