HELLO
CAN SOMEONE HELP ME IN A SITUATION IN ODK COLLECT THAT I WOULD WANT TO HAVE
THREE GROUPS OF QUESTIONS WHICH I WOULD WANT TO ANSWER IN DIFFERENT DATES.
I WOULD TO ANSWER THE FIRST SET AND THE HAVE AN OPCION THAT MAKES ME TO GO
IN THE NEXT SET OF QUESTIONS OR AN OPCION TO SEND ME IN TO THE END TO
FINALIZE FORM.
Hi
I am using xls I have tried the false but it didnt work. can you give me a
hint please
On Friday, January 30, 2015 at 10:30:30 AM UTC-6, Vasni Pech wrote:
> HELLO
> HAVE THREE GROUPS OF QUESTIONS WHICH I WOULD WANT TO ANSWER IN DIFFERENT
> DATES. I WOULD TO ANSWER THE FIRST SET AND THE HAVE AN OPCION THAT MAKES
> ME TO GO IN THE NEXT SET OF QUESTIONS OR AN OPCION TO SEND ME IN TO THE END
> TO FINALIZE FORM.
are you using xls or directly xml?
The logic is to use the relevant that if is false can skip the group.
Can you give it a try?
Bye
Angelo
Il giorno Fri Jan 30 2015 at 17:30:31 Vasni Pech ha scritto:
HELLO
TO FINALIZE FORM.
hi
THANKYOU ANGELO THIS KOBOTOOBOX WORKS PERFECT THIS IS AWSEOME THANKYOU I
TRIED IT AND IT WORED.
> HELLO
> TO FINALIZE FORM.
See the example, if you choose the red color the following group appears...
Can you try to start with http://www.kobotoolbox.org/#/forms try to create
your form and understand how xforms world works... but first of all read
the xlsform documentation... it's super simple!
Angelo
new_form.xls (5.5 KB)
Il giorno Fri Jan 30 2015 at 20:26:00 Vasni Pech ha scritto:
Hi
hint please
HELLO
TO FINALIZE FORM.
