How to start on ODK
Greeting ODK community ,
i would like to learn how to start on ODK ,
how to create ODK form upload it and then load the porgram and collect and
everything
could anyone make me an offer
i have an IT backgound wont make it hard on anyone
Regards
Saad Al-Dahwi
Hi Saad,
Please take a look at: http://opendatakit.org/use/
If you are stuck along the way post specific questions, detailing what you
are trying to achieve, what you have done, whats working and whats not
working.
Thanks and Regards
Ronald Munjoma
··· __________________________________________________________ The United Nations Millennium Development Goals A set of 8 goals, agreed upon by 189 member countries of the UN, that if achieved would see the greatest improvement to the human condition by 2015. http://www.un.org/millenniumgoals/
Action on the MDGs: www.mdgpledge.org
Change your sig: www.mdgpledge.org/sig/
everything
Regards
Saad Al-Dahwi
when i try to upload a Form it show me that error
Error: Problem with JavaRosa Parsing Form:
org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa
failed to construct a FormDef. Is this an XForm definition?
··· On Wed, May 7, 2014 at 12:44 PM, ronald munjoma wrote:
Hi Saad,
working.
Thanks and Regards
Ronald Munjoma
and everything
Regards
Saad Al-Dahwi
https://groups.google.com/d/topic/opendatakit/2GL_cYaCzHc/unsubscribe.
Hi Saad,
Where are you trying to upload the form? Please email a copy of xform.
Thanks and Regards
Ronald Munjoma
On Wed, May 7, 2014 at 12:44 PM, ronald munjoma simbiso@gmail.com wrote:
Hi Saad,
you are trying to achieve, what you have done, whats working and whats not
working.
Thanks and Regards
Ronald Munjoma
and everything
Regards
Saad Al-Dahwi
Dear Munjoma,
thanks alot for your reply
am cutting throw
hope i can be able to do it today :slight_smile:
regards
saad
Hi Saad,
working.
Thanks and Regards
Ronald Munjoma
and everything
Regards
Saad Al-Dahwi
Hi Munjoma,
convert XML to Xform ? can't find a converter or something o.O
regards
saad
Foxriver2.0.xml (4.44 KB)
··· On Wed, May 7, 2014 at 2:23 PM, ronald munjoma wrote:
Hi Saad,
Thanks and Regards
Ronald Munjoma
On Wed, May 7, 2014 at 12:44 PM, ronald munjoma simbiso@gmail.comwrote:
Hi Saad,
working.
Thanks and Regards
Ronald Munjoma
and everything
Regards
Saad Al-Dahwi
Hi Saad,
I dont think its possible to convert xml to Xform.
You can validate your xml file using:
Validating your xml file is giving:
Parsing form...
Title: "Foxriver"
XForm Parse WARNING: select1 question s [soooo much] should not
contain spaces, and are recommended not to contain apostraphes/quotation
marks
Problem found at nodeset:
/html/body/select1[@ref=/data/LOVEME]/item/value
With element
XForm Parse WARNING: select1 question s [Hate ya] should not contain
spaces, and are recommended not to contain apostraphes/quotation marks
With element
org.javarosa.xform.parse.XFormParseException: without proper
Problem found at nodeset: /html/body/select[@ref=/data/Howmany]/item
With element
With element
at org.javarosa.xform.parse.XFormParser.parseItem(XFormParser.java:928)
at org.javarosa.xform.parse.XFormParser.parseControl(XFormParser.java:664)
at org.javarosa.xform.parse.XFormParser.parseControl(XFormParser.java:602)
at org.javarosa.xform.parse.XFormParser$6.handle(XFormParser.java:159)
at org.javarosa.xform.parse.XFormParser.parseElement(XFormParser.java:375)
at org.javarosa.xform.parse.XFormParser.parseElement(XFormParser.java:386)
at org.javarosa.xform.parse.XFormParser.parseDoc(XFormParser.java:321)
at org.javarosa.xform.parse.XFormParser.parse(XFormParser.java:272)
at
org.javarosa.xform.util.XFormUtils.getFormFromInputStream(XFormUtils.java:72)
at org.odk.validate.FormValidator.validate(FormValidator.java:361)
at org.odk.validate.FormValidator.actionPerformed(FormValidator.java:257)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
XForm is invalid. See above for the errors.
Thanks and Regards
Ronald Munjoma
On 7 May 2014 14:01, Saad Al-Dahwi s.al.dahwi@gmail.com wrote:
Hi Munjoma,
regards
saad
On Wed, May 7, 2014 at 2:23 PM, ronald munjoma simbiso@gmail.com wrote:
Hi Saad,
Thanks and Regards
Ronald Munjoma
Hi Saad,
working.
Thanks and Regards
Ronald Munjoma
2015.
and everything
Regards
Saad Al-Dahwi
