How to sum variables in a repeat loop outside of the loop
I have added a repeat to record quantity and price of sells. now out of the loop using another variable, I want to sum the sells recorded in the repeat loop. how can this be done?
I believe this post will give you the answer you're looking for.
Welcome to the ODK forum! In the future, please do make sure to search for your question to see if an answer already exists.
Thanks a lot Helen. I will try it.
@Joaquin_Linares can you please share what you tried and what result you got?
