Dear all, I want to create variable as auto number in ODK.
It is unique number. Like record 1 is 1, record 2 is 2 ... record n is n.
Lihol
Lihol
Hi Lihol,
One reasonable way of doing this is to use repeats to wrap your
record. Then add a calculate variable with position(..) to track the
number of repeat you are on.
The above only works if all the records are in the same form. There is
no reasonable way to auto-increment numbers across forms in ODK
Collect. Your best bet is to use timestamps, but note that these are
based on device time which can be very wrong. If you just need to
uniquely identify forms, then use the instance ID
It is unique number. Like record 1 is 1, record 2 is 2 ... record n is n.Best,
Lihol--
Hi all,
I want to have a variable in my form which auto-increments based on no. of forms submitted in that project and returns last value. Is there any way I can do the same.
Thanks in advance for your help.
~~ Padmaja.
Try the ODK Counter app.
