Dear Community,
I am the beginner in ODK environment and I am developing a database to
collect information in health area.
My question is: How can I only allow to include uppercase only in text type
to avoid case sensitivity during data collection? For example, in the name
of the facility, name of the patient, etc.
I am looking forward to hear from you.
Best regards,
Antonio.
Hi Antonio,
Answer must beuppercase letters and between 1 and 10 characters long for
example
constraint= regex(., "^[A-Z]{1,15}$")
http://opendatakit.org/help/form-design/binding/
Le jeudi 17 juillet 2014 09:00:46 UTC, Antonio Niquisse a écrit :
> Dear Community,
> type to avoid case sensitivity during data collection? For example, in the
> name of the facility, name of the patient, etc.
> Best regards,
> Antonio.
Dear Community,
I am looking for the string function which can convert a lowercase to
uppercase in XML Form?
I tried this function :"upper-case()" but did not working.
Thanks in advance.
Regards,
Karim
Le jeudi 17 juillet 2014 09:00:46 UTC, Antonio Niquisse a écrit : > Dear
Community, > > I am the beginner in ODK environment and I am developing a
database to collect information in health area. > My question is: How can I
only allow to include uppercase only in text type to avoid case sensitivity
during data collection? For example, in the name of the facility, name of
the patient, etc. > > I am looking forward to hear from you. > Best
regards, > Antonio.
Hi Mokpokpok,
Thank you for your reply.
I forgot to say that I am using XLSForm. Therefore, I have included the
code you sent but it does not give any effect.
Is that code suit for XLSForm environment?
Best regards,
Antonio.
On Thursday, July 17, 2014 11:45:06 AM UTC+2, Mokpokpo ADJEODA wrote:
> Hi Antonio,
> example
>> Dear Community,
>> Best regards,
>> Antonio.
Hi Karim,
As the previous messages in the thread describe, you can prevent users
from entering text in a particular case, but transforms after the fact
aren't currently supported. Maybe they should be, so let's talk about
it.
Is there a reason you can't do this at the entry point or downstream
(e.g., during reporting)? Or put another way, why do you need this
feature in the XForm?
On Mon, May 22, 2017 at 1:13 PM, Karim Derra wrote:
> Dear Community,
> Thanks in advance.
> Regards,
> Karim
> the patient, etc. > > I am looking forward to hear from you. > Best regards,
>> Antonio.
> "ODK Community" group.
Hi Antonio,
type name label constraint text hh1 Your name regex(., "^[A-Z]{1,15}$")
Le jeudi 17 juillet 2014 10:17:42 UTC, Antonio Niquisse a écrit :
> Hi Mokpokpok,
> Best regards,
> Antonio.
>> Hi Antonio,
>> example
>>> Dear Community,
>>> Best regards,
>>> Antonio.
Thanks Yaw,
I make a pull data in the form with cascading selct. One of the key
variable is a composite ID which is initialy in upper case. e.g id=RE067.
When I want to keep the 2first two letters of the id variable, I got "re"
and not "RE".
I used this function :
substr(${id},0,2)
regards,
Karim
2017-05-25 15:08 GMT+00:00 Yaw Anokwa :
Hi Karim,
it.
On Mon, May 22, 2017 at 1:13 PM, Karim Derra kderra@gmail.com wrote:
Dear Community,
Thanks in advance.
Regards,
Karim
can I
sensitivity
regards,
Antonio.
To unsubscribe from this topic, visit https://groups.google.com/d/
topic/opendatakit/bzUx6paP8MU/unsubscribe.
The challenge with this approach is that although the user will not be able to proceed if he/she has entered lower case text they will still be able to insert lower case text and they will have to explicitly select uppercase letters while typing. This may be inhibitive or counterproductive.
Why not convert to upper case text post data capture if you require it to be uppercase.
Bashir
From: opendatakit@googlegroups.com [mailto:opendatakit@googlegroups.com] On Behalf Of Mokpokpo ADJEODA
Sent: 17 July 2014 03:36 PM
To: opendatakit@googlegroups.com
Subject: [ODK Community] Re: How to use Uppercase text only in ODK
Hi Antonio,
type
name
label
constraint
text
hh1
Your name
regex(., "{1,15}$")
Hi Mokpokpok,
I forgot to say that I am using XLSForm. Therefore, I have included the code you sent but it does not give any effect.
Best regards,
Antonio.
Hi Antonio,
Answer must beuppercase letters and between 1 and 10 characters long for example
constraint= regex(., "{1,15}$")
Dear Community,
I am the beginner in ODK environment and I am developing a database to collect information in health area.
My question is: How can I only allow to include uppercase only in text type to avoid case sensitivity during data collection? For example, in the name of the facility, name of the patient, etc.
Best regards,
Antonio.
This email is free from viruses and malware because avast! Antivirus protection is active.
Hi Karim,
This sounds like a bug with JavaRosa. I've filed it at
https://github.com/opendatakit/javarosa/issues/59.
What would really help is if you could upload a very small test form
to https://github.com/opendatakit/javarosa/issues/59 so a volunteer
could try to reproduce this bug. Please also note the version of ODK
Collect you are using so we can be precise with our testing.
If we can reproduce it, we'll try to fix it in the next release
(probably a month from now).
On Wed, May 31, 2017 at 1:28 AM, Karim Derra wrote:
> Thanks Yaw,
> I make a pull data in the form with cascading selct. One of the key variable is a composite ID which is initialy in upper case. e.g id=RE067.
> When I want to keep the 2first two letters of the id variable, I got "re" and not "RE".
> substr(${id},0,2)
> regards,
> Karim
>> Hi Karim,
>> it.
>> Thanks,
>> Yaw
>> > Dear Community,
>> > Thanks in advance.
>> > Regards,
>> > Karim
>> >> Antonio.
>> You received this message because you are subscribed to a topic in the Google Groups "ODK Community" group.
>> To unsubscribe from this topic, visit https://groups.google.com/d/topic/opendatakit/bzUx6paP8MU/unsubscribe.
>> To unsubscribe from this group and all its topics, send an email to opendatakit+unsubscribe@googlegroups.com.
Also, if you have fixed sets of names that the user should select, you
should consider using the select-one or select-multiple prompts, and
supplying the fixed set of values. For large sets of values, see
http://opendatakit.org/help/form-design/external-itemsets/
A typical use case is for cascading selects (e.g., choose province, choose
town, choose facility)
be uppercase.
Bashir
*On Behalf Of *Mokpokpo ADJEODA
Hi Antonio,
type
name
label
constraint
text
hh1
Your name
regex(., "{1,15}$")
Hi Mokpokpok,
Best regards,
Antonio.
Hi Antonio,
example
Dear Community,
Best regards,
Antonio.
Options: http://groups..google.com/group/opendatakit?hl=en
http://www.avast.com/
http://www.avast.com/ protection is active.
Hello everyone, I was wondering if it is possible to force user to enter only Upper case letter with digits and only 11 characters. For example "AA11AAAAAAA"
Looking forwards for your answers.
Best regards,
Hi @Anil_GUNAYDIN
you need to use regex
here is a sampleuppercase.xlsx (5.3 KB) form that should work for you:
Hello @Grzesiek2010 thank you for your quick reply. this formula force users to enter upper case letter but I wanted to force them to enter both upper case letter and numbers . Could you please help for this question also ?
Kind regards,
For 11 characters, and accepting either capital letters or numbers, change the regex expression to:
regex(.,'^[A-Z0-9]{11}$')
Thank you so much for your help and it works @danbjoseph
HI! thanks for the reply, but I was looking for something that converts to lowercase without bother the user during the form filling, telling him using only upper or lower case, for example, when filling an email field: I don't care how the user write it down but I want it in the database in lowercase...
Is there an option to achieve this?
thank you!
No, at this moment there is no function to do that automatically.
For posterity's sake... You can use translate in a calculate field, like this:
translate(${THE_FIELD},'abcdefghijklmnopqrstuvwxyz','ABCDEFGHIJKLMNOPQRSTUVWXYZ')
