Hi all
I create server with Google App Engine , my question is how change the ID project.
Thanks advanced
Google Cloud's project ID can't be changed as far as I know. You can always change the project name but not the project ID.
If you really want to change project ID, you will have to create a new project but even so, it doesn't allow you to edit the project ID since it is automatically generated.
You can choose your project ID as long as someone hasn't taken it.
For example, someone already uses the project ID odk-collect (for the URL odk-collect.appspot.com), resulting in a similar project ID to be odk-collect-[randomnumbers]
Meanwhile, no one has used the project ID i-am-jruizc (for the url i-am-jruizc.appspot.com). Thus I can grab the project ID i-am-jruiz without those random numbers generating.
Thanks for your answers but , I did not understand how to edit project ID.
Thanks advanced
