I'm trying to up a form in a page http://opendatakit.org/use/xlsform/ but
the module does not appear to me, anyone knows what happened?? or is it
just my problem??...
XLSForm looks down to me too. It's a holiday weekend in the states, so
I doubt there will be a quick fix.
Source for the converter is at https://github.com/SEL-Columbia/pyxform
if you want to try to run it offline. You can also try
http://formhub.org.
-- Need ODK services? http://nafundi.com provides form design, server setup, professional support, and software development for ODK.On Fri, Nov 29, 2013 at 2:04 PM, cbms.aru@gmail.com wrote:
the module does not appear to me, anyone knows what happened?? or is it just
my problem??...--
If you're using Windows you can also try using xlsform.exe for offline
conversion:
https://code.google.com/p/opendatakit/downloads/detail?name=xlsform%20v0.9.18.zip
I just an updated build using the current master branch of the pyxform
repository Yaw linked you to.
Regards,
-Nathan
On Friday, November 29, 2013 2:04:01 PM UTC-8, cbms...@gmail.com wrote: > > I'm trying to up a form in a page http://opendatakit.org/use/xlsform/ but > the module does not appear to me, anyone knows what happened?? or is it > just my problem??... >Nathan very Thanks!!! the xlsform save me, I download a old version and
dont have converter, but with this version is fantastic.
2013/11/30 NathanIf you're using Windows you can also try using xlsform.exe for offline
conversion:https://code.google.com/p/opendatakit/downloads/detail?name=xlsform%20v0.9.18.zip
Regards,
-NathanOn Friday, November 29, 2013 2:04:01 PM UTC-8, cbms...@gmail.com wrote:
I'm trying to up a form in a page http://opendatakit.org/use/xlsform/but the module does not appear to me, anyone knows what happened?? or is it
just my problem??...--
https://groups.google.com/d/topic/opendatakit/7PfykZqZwME/unsubscribe.
