HTTP Status 500 - persistence layer problem
Hi Everyone,
I just noticed that I cannot log into my Aggregate instance via my browser. I already searched the forums but this exact report doesn't match on any thread.
I get the following report on each log in attempt.
HTTP Status 500 - persistence layer problem; nested exception is org.opendatakit.common.persistence.exception.ODKDatastoreException: org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
description The server encountered an internal error that prevented it from fulfilling this request.
exception
org.springframework.dao.TransientDataAccessResourceException: persistence layer problem; nested exception is org.opendatakit.common.persistence.exception.ODKDatastoreException: org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
	org.opendatakit.common.security.spring.UserDetailsServiceImpl.loadUserByUsername(UserDetailsServiceImpl.java:206)
	org.springframework.security.web.authentication.www.DigestAuthenticationFilter.doFilter(DigestAuthenticationFilter.java:159)
	org.opendatakit.common.security.spring.DigestAuthenticationFilter.doFilter(DigestAuthenticationFilter.java:40)
	org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)
	org.opendatakit.common.security.spring.OutOfBandUserFilter.doFilter(OutOfBandUserFilter.java:105)
	org.opendatakit.common.security.spring.Oauth2ResourceFilter.doFilter(Oauth2ResourceFilter.java:352)
	org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116)
	org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
	org.springframework.security.web.access.channel.ChannelProcessingFilter.doFilter(ChannelProcessingFilter.java:157)
	org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)
	org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)
	org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
root cause
	org.opendatakit.common.persistence.engine.mysql.QueryImpl.executeQuery(QueryImpl.java:273)
	org.opendatakit.common.security.spring.RegisteredUsersTable.getUniqueUserByUsername(RegisteredUsersTable.java:310)
	org.opendatakit.common.security.spring.UserDetailsServiceImpl.loadUserByUsername(UserDetailsServiceImpl.java:159)
root cause
	org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80)
	org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:619)
	org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:684)
	org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:716)
	org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:726)
	org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:776)
	org.opendatakit.common.persistence.engine.mysql.QueryImpl.executeQuery(QueryImpl.java:266)
root cause
	sun.reflect.GeneratedConstructorAccessor154.newInstance(Unknown Source)
	sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	java.lang.reflect.Constructor.newInstance(Constructor.java:526)
	com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
	com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:989)
	com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:341)
	com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2192)
	com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2225)
	com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2024)
	com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:779)
	com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47)
	sun.reflect.GeneratedConstructorAccessor30.newInstance(Unknown Source)
	com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:389)
	com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:330)
	org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:39)
	org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:256)
	org.apache.commons.pool2.impl.GenericObjectPool.create(GenericObjectPool.java:868)
	org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:435)
	org.apache.commons.pool2.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:363)
	org.apache.commons.dbcp2.PoolingDataSource.getConnection(PoolingDataSource.java:134)
	org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1533)
	org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
	org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
root cause
java.net.ConnectException: Connection refused (Connection refused)
	java.net.PlainSocketImpl.socketConnect(Native Method)
	java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
	java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
	java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
	java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
	java.net.Socket.connect(Socket.java:580)
	com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:211)
	com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:300)
note The full stack trace of the root cause is available in the Apache Tomcat/8.0.43 logs.
Not sure. I could log in perfectly well a few weeks ago but now I can't.
I have attached the same error report on a text file.
Thanks for the assistance.
SpaceTurtle
Hi, @SpaceTurtle!
The error is telling us that there's some communication problem between Aggregate and your MySQL database server.
Could you check if it's up, running, and accepting connections?
You could always try rebooting the server if that's something you can do.
Hi. You may have already found this in your searching, but does this help?
