Https://odk12369.appspot.com/
My https://odk12369.appspot.com/ shows me quota exceeded when I want to subscribe. I submit firstly 200 nos data and then again try to submit 200 nos data at a time from 5 different android mobile with using one hotspot. I submit my last 200 nos data approximately. According to the browser link, I go my google console, but there I can not find odk12369.appspot.com ID.
I use google app engine and try to reach the server from the mobile data with a windows laptop and tab.
please solve it. I invest my money for this survey, so if the data loss, maybe I lose my job.
I go my google engine but I can not see the areas according to the browser description.
First of all, you do not need to panic. Looks like your data is safe. However, you may consider following the below steps:
  1. Secure your server by logging into the Aggregate server with the default password and uncheck all access to the anonymous user.
  2. On your Google cloud, set up your billing plan to avoid quota issue and you will get free access for a year
  3. User briefcase to take backup
If you are running a survey, you need to ensure, your data is secured. To learn more about ODK please read the comprehensive documentation on: https://docs.opendatakit.org
Thanks for response. Yesterday I figured out my problem.
Planner Md. Ashaduzzaman
