Hyperlink using markdown doesn't work when referenced to the calculated field (enketo)
Using ODK Cloud
I have a calculated field using concatenate() to construct a dynamic link.
The hyperlink in label and hint for note doesn't work in enketo when a ${calculated_field} is placed inside the markdown hyperlink like [calculated field](${calculated_field}). However, if it is a static link, it works as described in the documentation.
The output I got in the note hyperlink for different languages are stack on each other, as follow,
" rel="noopener" target="_blank">re-register
" rel="noopener" target="_blank">mendaftar
The name of the function is concat(), please, see https://getodk.github.io/xforms-spec/#fn:concat.
Could you temporarily change the type of the calculate to text, please? So, you can test, if the calculation works fine.
check this post:
The url appearance does work well with text and calculation. It will display the clickable url. For the time being, there isn't a way to do something like <a href="">Text</a>, to display clickable text instead of the url itself.
For my case, the url is a bit long and it is not being wrapped properly in the enketo form. It is just a bit nuisance, but functionally it does works. Thanks.
