Hello so i have neen trying to set up google app engine i have no coding skill i need help
It sounds like you'd like to use ODK Aggregate on Google App Engine? I wouldn't recommend that because Aggregate is no longer being updated.
ODK Central is the replacement, so I'd recommend you start there. You can use Central on ODK Cloud or read the docs to self-host.
